Sabretooth007ExplorerOct 30, 2017Fresh Water Tank Drainage ?I have a 2017 Crusader 32 ft 5th wheel when I drain the fresh water tanks it seems to take forever? Is there a quicker way to drain them or a modification that will make the flow faster?
troubledwatersNomadOct 30, 2017I am guessing you don't want to cut a bigger hole in the bottom to make it drain faster - so unless it's gulping air, no.
Related ContentWater pump?Why no hot water?Fresh water tankfresh water hoseExternal Water Fresh water Tank
