Sabretooth007
Nov 01, 2017Explorer
jalichty wrote:
What's the big hurry to drain the fresh water tank? I would assume you are through for you trip and just want to drain it. Why not just take it home, open the valve and then do some other things around the house or trailer for a while. That's what I do and I realize it takes a while, but since I'm not going anywhere very soon, it's not a big deal.
Quote : - If you are in a big hurry, open the tank drain, and also open the low point drains. Turn on the water pump and the water will be emptied in a very short time. Be sure to remember to close the low points before you use the trailer again
Barney -: Quote.
Its not a matter of being in a rush, But if you use a dump station people get angry because it takes so long, letting it drip run while driving down the road is illegal and you can't just let X amount of water out in a camp ground or on the side of the road. And watering the plants is a no no in an apartment ! At present I use a drain in the complex but I can't do it for ever. So I guess a bigger outlet is called for...
Cheers
About Fifth Wheel Group
