Snowman9000 wrote:
On our Crossroads Cruiser, the pickup came off the side of the tank near the bottom but leaving the last inch or two in the tank. When the tank is only 6 or 8 inches tall, that's a lot of water that can't be used. The fix was to unscrew the piping elbow fitting and make up a new one that had a pickup tube attached to it. The tube was fitted so it ran down to the bottom of the tank.
Agree with this. And if you happen to be off level a bit it could even makes it worse. There was a bunch left when empty with our first trailer. I took off part of the bottom and put a couple of 2x4s across and under the tank on the opposite side of the pick up tube. Then the water had to go down hill. It got about every drop out after that.
