high desert wrote:
mr. old style wrote:
Jim Cindy wrote:
I like high deserts solution to use the tank drain lines for pump supply. Should make all the water capacity usable.
Therein lies the problem. The front tank has no drain line. The only way for water to get out is through the connection to the other tank which is 1 1/2" above the bottom (measured) making it theoritaclly(sp) impossible for it to drain.
I would definitely add a drain to that tank. You can use a spin weld fitting that will make the job fairly easy.
That would work do you have a source for the fittings?
