flrp's avatar
flrp
Fresh Water Vent Cedar Creek Silverback 29RE
I just purchased a new Cedar Creek Silverback 29RE and I can't find the fresh water air vent. I want to sanitize the tank and need to add the bleach solution in the fresh water vent. When I picked up the new RV I asked about the vent and they didn't know where it was either. Now I know there must be one because it next to impossible to add water to a fresh water tank with the exhaust air vent. I have looked all around the RV but I can't fine it. Does anyone know where it might be?
  • Without removing underbelly to gain access to fresh water tank you will not be able to get at tank vent line.......really not necessary to sanitize the vent line.
    You fill your fresh water tank via 'fill' valve at water panel.
    At 1/4 cub per 15 gallons....figure out how much bleach you need then pour it into hose, connect it and fill tank
  • Look under. Mine is under the left side just aft of the fill.
  • yours has a valve where you put the water hose at then turn the valve down it fills your tank you will have to make a siphine hose to put the bleach into the unit
