jstaffon's avatar
jstaffon
Fridge in slide-out
It seems like I've seen posts in the past about refrigerators in slide-outs and the fact that they have a problem in warmer temperatures. The cooling fan behind my Dometic RM 1350 seems to run a lot during hot weather. I've seen posts in the past about air flow and fan mods. Does anyone have pictures or drawings for such mods. Thanks in advance!
  • Our 2001 with refer in the slide seems to work fine without any problems. So did our previous rig.
  • I would think the direction the RV (location of the fridge) faces the sun matters a lot. Is there a tree shading it, etc.
  • A camping neighbor and I were chatting about dry camping and he was disappointed in that he didn't realize at the time of purchase that his frig in the slide had an extra fan in it and that it increased his battery discharge and lessened his ability to extend battery life without recharge.
  • The reason that they don't cool as well in a slide is there is no roof vent, they have to vent from the side which is not nearly as efficient. That is why when installed in a slide a cooling fan is required.
    tinner12002 wrote:
    I guess I don't understand why you'd have issues just because the frig is in a slide. The only difference that I can think of is that when slide is out its all sticking out away from the side of the trailer. They are still in the same cabinet configuration regardless of whether its in a slide or otherwise...what am I missing?? Most toy haulers out there have the frig in a slide if it has 2 or 3 slides, I'm sure its the same on a 5ver.
  • Tinner, the issue is the vent is on the face of the slide versus out the top. The natural flow of hot air is blocked.
    I have had my fans fail and the temps go up quite a bit. I added two more fans at the base of the refer coils since we camp in really hot weather.
  • I have a Norcold frig in my slide and was having similar issues related to its cooling ability. This was especially true during our beach camping (which is most of our summer trips). I also had concerns about the Norcold fridge recall and the potential for fires.
    I solved both these issues by installing an ARP module wired into the fridge controller. The install was a little tricky but the vendor has great tech support. Go to the below website for more information
    https://www.arprv.com/index.php
    Hope this helps,
    Bryan
  • I guess I don't understand why you'd have issues just because the frig is in a slide. The only difference that I can think of is that when slide is out its all sticking out away from the side of the trailer. They are still in the same cabinet configuration regardless of whether its in a slide or otherwise...what am I missing?? Most toy haulers out there have the frig in a slide if it has 2 or 3 slides, I'm sure its the same on a 5ver.
