Old-Biscuit wrote:
Inverter supplies 120V AC...it is a draw off batteries
Do you not have a converter?
If batteries only supply DC System then you will not have issue with AC Ripple.
AC Ripple is a result of Converter using 120V AC to supply DC
No converter.....no AC Ripple
Only mentioned AC Ripple due to the number of circuit boards you have changed out.
The boards were a problem on their end. They told me they had a bad batch. The current one is the newest format and programming.
No sir....I have a xantrex freedom 458 inverter/charger that controls two outlets in the trailer and charges the house 12V DC and gives me 110V from 12V DC to power some items in the trailer when the ONAN 5500 is not running
I am in the process of isolating the coils. So far the heating element is hot as hades and the heat stops right at the top of the coils before the condenser.....will go no further. It has been 3 hours so far. Not a hint of temp change in the freezer or fridge. By this time I would have felt a temp change in the freezer given past performance
I did confirm the 60 cfm fan and therm switch work. I am going to install one 200cfm fan instead of two 60cfm fans since the room is limited and I don't want it melting next to the flue.
Old biscuit....questions for you sir.Any ideas on the:
-thermistor modification I posted earlier in the thread? I tested the thermistor and it is within Ohms range but its out on the floor why not change it or modify it. What are your thoughts on the mod?
http://www.snip-the-tip.com/cgi-bin/articca.cgi-where I can get a new two prong therm heat switch for the fan (its way up there and I'd rather change it now that its out and in my garage.)
Thank you very much for the help!
Joe
