joe_blow's avatar
joe_blow
Fridge WOES......Again
Hi all,
2008 WW CR3705 with the Dometic RM3862 fridge. I have been balls deep into this fridge several times. The first was the ciruit board. I bought one from dinosaur electronics and it worked well for a year. The same board had an ignitor issue and the board was warrantied. Long story short this current board is the third in a series of "warranty" boards.
So I plugged my trailer in on Tuesday (flat ground). The freezer and fridge are perfect by the 24 hr mark. Come Friday I went to load a bag of ice into the freezer and the thing was warmer than it should be. I checked all lights, fuses and it was all in check. No "CHECK" light on.....nothing.
Needless to say I transferred over to propane (bled the lines and all was good...fridge burner/pilot on). I got to my destination and it was 68*
I am so sick and tired of this unpredictable fridge and/or the dinosaur board.
I am going to get into to it tomorrow and check the obvious but at this point I am at a loss.
Any ideas on what might be the issue?
Is the fridge done?
Thank you
Joe
  • no matter what, you have to have a good 12volt supply. I had your problems one time,found a loose wire was the hole problem.
  • Does it have assist fan or fans in the back outside of the fridge to move air? If they burn out it can breathe and while freezer will be cold the fridge will not.
    Just a thought.
  • Old-Biscuit wrote:
    CHECK light only comes on IF propane FAILS to light off....nothing to do with AC operation
    No pilot flame..........only a main flame when propane lights.
    Thermostat controls heating cycle (flame or electric element on/off)
    Low Ambient Temp (LAT) Switch.............make sure it is OFF (when on keeps interior light on causing excessive heat)-No bulb in the fridge
    What/how are you measuring temps? thermometer normally but this time I used a remote probe with a t/stat outside the fridge. I can tell you it was nowhere near how cold it is when working
    What temp setting.......max (5)? Yes, I never change the temp
    Test for circuit board or cooling unit
    Electric element leads -----unplug them from circuit board and plug them DIRECTLY into the 120V AC outlet
    Run for 24 hrs
    This bypasses board......
    If fridge cools down freezer should be 0*F and food section should be 32*F or lower ---circuit board bad
    If circuit board bad (AGAIN) then you need to check your DC System for amount of AC Ripple (Dirty DC).
    AC Ripple is result of converter capacitors failing allowing AC Voltage onto DC System
    To Test for AC Ripple.....just like testing DC Voltage except multimeter set to AC Voltage and then you take a reading on DC Circuit....can be done at converter or right at fridge DC terminal
    Over 1 volt AC can cause circuit board failures
    If fridge does not cool down (freeze might but food section doesn't) then cooling unit is blocked
    Both freezer and fridge were equal temps by the time I got to my camp area. I just turned it off and decided not to think about it
    I will check all this tomorrow....thank you
  • CHECK light only comes on IF propane FAILS to light off....nothing to do with AC operation
    Run for 24 hrs
    If fridge does not cool down (freezer might but food section doesn't) then cooling unit is blocked
  • Most likely not the problem......but thank you for the help
    In AC and LPG mode the fridge lights are on, the burner is on in LP mode and still no cooling.
    Artum Snowbird wrote:
    The way you describe it is like the 12V battery voltage is low. You need to check the voltage at the converter output, and at the battery when plugged in. Your charge voltage may not be reaching the battery, and then when the battery goes low, the fridge shuts down.
    It might not be the problem, but it's worth checking your battery voltage to see, and it's the source of a lot of problems that don't look like a bad connection.
    My fridge was not faulting, but the idiot light dropped to one bar out of four while I was plugged in, and I found a loose negative connection at the converter. I wiggled the wire, and the inside lights all jumped up in brightness. Tightened the connection, and all was well.
  • The way you describe it is like the 12V battery voltage is low. You need to check the voltage at the converter output, and at the battery when plugged in. Your charge voltage may not be reaching the battery, and then when the battery goes low, the fridge shuts down.
