R_-_E_W9
Mar 03, 2015Explorer
I added insulation after I discovered only 5 pieces of loose batting hanging in front of the closet.
I had to remove the front cabinet to access the void between the closet and the front cap.
2 ft x 4 ft 3/8 foam sheets with foil on one side and clear plastic on the other. its flexible enough to attach to the fiberglass using spray glue
(you need ventilation)and insulation tape. I put 2 layers in our Crusader,also covered the back of the closet, made a world of difference,
Not a easy task but worth the time.
About Fifth Wheel Group
