BobKrogstie
May 03, 2015Explorer
The nut on the bolt holding the linkage arm from the drive motor to the passengers side leg may be coming loose and hitting on the drive motor. I have a similar issue but it's because the bolt put in by an RV repair outfit is too long and it is hitting on the motor body making a "clunking" sound. I'd check the linkage nut and bolt.
About Fifth Wheel Group
19,033 PostsLatest Activity: Jan 20, 2026
