micar wrote:
Thanks for the replies, what I'm trying to answer is, will the 8' box require more swing room than the 6.5' or will the difference be cancelled out by the trailer sitting further into the box?
Thanks Mike
Nope, your trailer will be close to the same distance from the END of your truck no matter which box you have. If the hitch were mounted further into the truck bed you wouldn't be able to turn without coming into contact with the "belly" of your fifth wheel and the bummer of your truck. What is going to be different is your turning radius as stated earlier.
Do yourself a favor and go test drive a new CC long box just to get a feel for the difference in the steering, Go to a parking lot and try parking the new truck in a parking stall then you'll really understand what we're talking about.
There will be spots you're NOT going to get into, maybe with a little "giggling". It's not really all that bad. After a few trips with the longer truck you'll be a pro at deciding what you can get into and what to pass up.
Dan
