sidney's avatar
sidney
Front hydraulic landing gear settling
We have a 2014 Cedar Creek 5th wheel with the Lippert hydraulic 6 point leveling system.
Recently the front landing gear has started to settle slowly after being set up... approximately 1/8" per day. Also when the gear is retracted when towing the front left (curb side) landing gear will extend slowly about an inch after we have been towing all day.
I inspected the system and found no hydraulic fluid leaking anywhere.
I called Lippert to help troubleshoot and they said to make sure the hydraulic cartridge valve on the right side landing gear was fully closed by turning counter clockwise with a 5/32 allen wrench. I was able to turn the valve about 1/4 turn or so but I don't know yet if it has fixed the problem. (I don't think so)
I'm afraid we may have an internal leak in the front left jack assembly. Lippert told me they do not sell parts to rebuild the jack assembly... if there is an internal leak I would need to buy a whole new jack assembly... they are very expensive and a pain to remove.
What if I do nothing and continue to re-level every few days? Are we risking a dangerous failure?
I was thinking of using more leveling blocks under the pads so we would only need to extend the jacks a couple on inches. That way if it did start settling faster the front could only lower a couple of inches.
Anyone have experience with this same problem?
What options do I have?
Thanks
