nayther wrote:
It's probably the shear pin skipping in the drive gear. The top of the leg has a gear that is driven by the motor and its brass with a slot that a roll pin sits in, if you drive the leg all the way up or down until it bottoms/tops out it can make that roll pin skip and eventually wears out the brass gear. It is designed that way so you don't break the worm gear that drives it up and down. They sell a kit with new thrust bearing, gear, pin, etc. Anything else needs repair and you have to replace it they said due to liability.
Camorhino:
Where did you get the dual motor kit? I need to do that real bad, maybe replace the one existing motor too as its laboring real bad, might be about gone.
Thanks for the info as this is probably what happened in my case as I dropped the front all the way down on the trip we just returned from due to the extremely uneven camp spot. I did not know this was a problem.
Where do I get one of these kits?
