Ezbagr
Oct 03, 2013Explorer
This is the way that I level
1. pull in or back into site
2. check level side to side-adjust if necessary by placing shims, blocks,etc under low side tires.
3.Chock tires
4.lower front landing-adjusting landing gear feet so they contact ground at same time-adjust by using separate buttons as in wilbur1`s
setup or by using adjustable foot on one side which is what i use.
5.Raise trailer by extending both sides of landing at the same time and same travel-raise high enough to unhook
6. unhook and pull truck out of way.
7. check front to rear level and adjust if necessary with front landing gear by raising or lowering again, at same time and same travel.
8. lower rear jacks.
3.Chock tires
About Fifth Wheel Group
