wilber1
Oct 03, 2013Explorer
Ezbagr wrote:wilber1 wrote:Ezbagr wrote:wilber1 wrote:Ezbagr wrote:wilber1 wrote:Ezbagr wrote:wilber1 wrote:fj12ryder wrote:
I've often wondered with the two motor independent system how you know that both legs are moving at the same time to raise the trailer in sync. Obviously once both legs are in contact with the ground you can't tell if you raised or lowered one leg more than the other. Can the switches be interlinked so they work together?
Later models than mine had a third switch that ran both motors. The speed they run at is very close. Our procedure is run each leg down till they are just touching the ground, then I hold both switches and raise the trailer until I can unhook. Once unhooked, I hold both switches and lower it until the trailer is level fore and aft. Then I level it side to side by raising one and lowering the other at the same time. That maintains the fore and aft level while leveling side to side. It works very well as long as the ground isn't too sloped.
For hooking up, I just run them together like they were a single motor system.
wilber1, it is not so good to do it the way you described. You first need to level side to side before lowering legs.
Doing it the way you described you ARE TWISTING the frame.
If you level side to side at the front and the wheels aren't on dead level ground, you are twisting the frame anyway. Independent jacks just make the process easier, they don't replace the need to block up wheels if the ground is very uneven.
It is physically impossible to level the whole trailer side to side with the front landing gear. I don`t understand leveling the front of the trailer side to side?
You level inside trailer floor first and then lower jacks separately in your case until the both touch the ground and then raise or lower together if needed.
And how do you "level the inside floor".
By shimming, blocking etc. low side tires.
You have to do that with independent jacks as well but you can be much less exact about it. If the ground is fairly level, you don't have to do it at all and can still get the trailer quite level with just the front and rear jacks. We use a spirit level but my wife's real criteria is the bathroom door. If it doesn't move, regardless of what position it is left, the trailer is level.
Anyway, I've been doing it with this trailer for 11 years and haven't twisted or broken anything despite finding out that one jack will support the whole front of the trailer when one switch stuck on when I released it and I didn't notice.
wilber1, you need to go back to the beginning of the this thread. It is about making the front landing legs contact the ground at the same time thus eliminating frame twist.
Contrary to what you say, leveling side to side with front landing gear is NOT GOOD for trailer frame. Good for you that this has been the way you are doing it and has not caused you any problems but I will continue to use IMHO the correct way-level side to side,lower landing gear, adjust landing gear so both feet contact ground at same time,unhook,level front to back.
That's exactly what individual jacks allow you to do. They also allow you to fine tune side to side leveling after you have blocked the wheels. Frames are flexible and are subject to uneven and changing loads all the time as you drive down the road. They have to be because G forces from hitting every bump and whoopee on the road will change the loading on the frame. How you load your trailer and extending your slides also changes the loading on the frame.
About Fifth Wheel Group
