nicol619 wrote:
my 2006 montana fifth wheel front landing jacks will raise my fifth wheel so far then just makes a racheting noise. I drop it a little then raise it again get to the same point and does the same thing. tryed the hand crank and can hardly move it they are electric [email protected]
bfast54 wrote:
Where are the LOWER LEGS set at,and If you ask..WHAT......??????........
Then,theres your problem.....:W
New member, maybe new to 5er.
To the OP, the front landing gear have an inner set of leg extensions, I normally lower the outer (powered) legs 4" to 6" then drop the inner legs to the ground and lock at the nearest pin hole. You may have manual clips, or spring loaded pins, just be sure the pin goes all the way through both sides and is locked in place.
Then once disconnected from the TV, you can raise or lower to level as necessary.
