wantabe351
May 16, 2018Explorer
Go to home depot or any hardware store and get a piece of angle iron and run it frame beam to beam c channel or I beam that they use for a frame and drill a 5/16" or 3/8" hole for the bolts your using..a 1.25 x 1.25 size angle iron should be more than enough to hold you battery boxes and some, Plus if the floor of the front is to thin put down a 1/2" plywood..
About Fifth Wheel Group
19,035 PostsLatest Activity: Mar 21, 2026
