DmaxWW wrote:
Pop-Pop C wrote:
I agree, probably not enough wt. on the pin.
12,700 on the trailer axles, 3200 on the pin, 25,900 gross, gives me 25.8% on the pin. Trailer rides level on two 7k axles with mor ride equalizers and shocks on both axles.
Axle wt 12,700 + pin 3,200 = 15,900/3,200 = 4.9685 100/4.96875= Pin wt 21,125%
My rig in sig is 12,600 on 7k axles and 3100 on the pin or 19.75% also have 2 in riser on trailer suspension. Demco Glideride and B&W companion hitch. I run level with 7in clearance and only occasional slight chucking on bad roads. Most of the time I forget it's back there.
Check your trailer suspension.
