ksg5000 wrote:
You know where the water lines run - open up access to those areas and use hair dryer and/or light bulb to provide some heat in those compartments. Also - when in doubt use your onboard water rather than the campground hookup which has its own freezing issues. Patience is the operative word - things will thaw out.
our hookups are inside our storage, so we did put a heating fan in the storage compartment for the lines that run along there i guess. we have heating fans going inside the cabinets with sinks above them, so hoping that helps.
