fallonator22 wrote:
GordonThree wrote:
Had my valves freeze once, before I installed heat tape on them.
The hair dryer didn't do anything, or at least not with my patience - a 30 sec blast on high wasn't working.
So I got an extension cord and 1500 watt forced air heater and aimed it at the valve. After a half hour break for soup and cocoa it was ready to dump.
when you say aimed it at the valve, you mean you approximated where it was and blew it through/straight at the underbelly, or you took off the underbelly and found the actual valve and blew it at it?
OH! Ok it just now hit me. Of course they are where I pull them. It’s not like I pull them out by the dump and they undo somewhere else under the RV. Duh. I got you- thank you!!!
