work2much
Mar 22, 2017Explorer
Try using RV trader for a used rv. If you are willing to travel to pick it up you should be able to find what you are looking for. Keep in mind that high quality units are typically very heavy and you may need to look at pin weights and what your SRW can accommodate. Actually with any 5th wheel over 30 feet you may run out of GVWR on your truck.
You should be able to find a used DRV Mobile suites in the 60k range but they are very heavy. Dually or bigger. Might also check out Outdoors RV and Arctic fox which are in your rang. Their construction materials and methods are better than most especially in the trailer frame.
Good luck with your search.
About Fifth Wheel Group
