N-Trouble's avatar
N-Trouble
Fuel station grounding wire
On my new trailer they include a cable with clamp in the fuel station for grounding purposes I assume. My old trailer never had one and I've seen plenty of others without. I would like to rip the thing out since its in the way and gets tangled up in the hose. Anyone actually use one of these?
  • If it worries you, replace your fuel nozzle hose with one that has a built in static wire.
  • It is there to dissapate any static electricity that may have built up either by riding or your rubbing against the plastics on your toys. Static electricity is everywhere, so if you are willing to take the chance that it wont happen to you I would use it.
  • copeland343 wrote:
    Its a bonding wire. For example, if a storm is coming and you try to refuel with out it you will know why you need it. Mobile fuel needs it because you are not grounded (unless you are plugged into electric power)you want to bond before you put nozzle in tank and start dispensing fuel the fuel falling into tank will cause a buildup of static charge. Service station pumps are grounded and the hose touching the filler neck bonds you to to pump then to ground.
    I have one on mine also, never used it. Most ATVs have plastic fuel tanks. so I dont see the point.
  • I don't have the wire, but if I did and it was in the way, I'd get rid of it.
  • Its a bonding wire. For example, if a storm is coming and you try to refuel with out it you will know why you need it. Mobile fuel needs it because you are not grounded (unless you are plugged into electric power)you want to bond before you put nozzle in tank and start dispensing fuel the fuel falling into tank will cause a buildup of static charge. Service station pumps are grounded and the hose touching the filler neck bonds you to to pump then to ground.
