MaxAZ
Sep 26, 2012Explorer
Repairing fuel station pump
My pump wasn't turning on so I loosened up a couple of bolts on the gear cover panel and then it started pumping again. Wasn't leaking or anything after loosening the bolts but I investigated some more and removed the gears. I noticed that the gears had been rubbing pretty good on the cover panel so I got out some sand paper and sanded down the gears so they weren't so wide. After I put it all back together it was working pretty good at first but then slowed down and wouldn't run unless I loosened the bolts again. I plan on taking the gears out and sanding them some more to see if that fixes it up before I have to replace them but I was wondering if these plastic/rubber gears don't wind up expanding some over time while soaking in gas all the time. Any other opinions out there before I tear into it again.
