First off I run the generator once a month under load, year round also the fuel station just open fill cap and stick nossle back in there and run it for a few minutes also I use nothing but non ethynol fuel. If your blowing fuses most likely your impellers have swollen and jammed against the outer plate. Pull out the motor and take out the four screws, then pull the plastic impellers if your have a belt sander sit down put it upside down between your leggs turn it on using 1000 grade sand paper hold the gear flat against the sand paper for 2-3 seconds at a time do this 2-3 times make sure you hold it flat that will be enough to take the swelling out of the gear put the plate back on, making sure the gasket is in the groove properly cause its a hair bigger than the gasket track tighten the four bolts and run the pump, if you still get nothing or just s little repeat process until its running smooth don't remount motor till its working that part is a pain in the a$$ and change your fuel this will also save the carbs and prevent future issues
