GlampinLife
May 09, 2016Explorer
Fueling station/Generator Gas Tanks/Filling Question
I've got a 2016 Jayco Seismic Wave 310W that has 2 gas tanks (generator and fueling station). I've only used it once and noticed when I filled up both tanks how long it took because you could only pump the gas so fast without it turning off like the tank was full. I didn't think of anything at the time other than you couldn't fill it up fast (like you can a car).
This past weekend I went to use my new Gastapper Transfer Pump to transfer fuel from the generator tank to the fuel station to empty both tanks, I use the fuel station for my lawn mowers and wife's car. I just don't like the idea of the fuel sitting in those tanks for a month or longer.
So as I went to feed the hose in the tank, it wouldn't go in very far. I looked in and there are green balls in the neck, just past where the gas nozzle would reach. I can't find much info about this... what's it for, the need and can it be removed.
You can kind of see it in this picture I took:
