Carl_n_Susan
Sep 12, 2016Nomad II
Arcamper wrote:GHop wrote:
I don't have a solution for your problem, but we have the same issue with our six point leveling system. Due to the problem, we don't use the auto level and just put blocks under the wheels to level our unit. In my opinion, the auto leveling system is a waste of money. If you have to be on level ground, why have auto level.
You will probably find yourself in the minority that the 6 point system is a waste of money. I have been in spots where it lifted tires off the ground to level the unit. I have also put blocks under the jacks if the rams where not long enough. Most on here say they would never have another trailer without the 6 point system including me. I wonder if there might be something wrong with yours causing the problem.
I couldn't agree more! I have used the Level Ups in extreme situations many times. You do have to know how the system works and its limits so you can adjust to a bad site.
About Fifth Wheel Group
