clev
Jul 23, 2015Explorer
Furnace problem
I may need to replace the furnace; I really don't know why because it's 'only' 21 years old. Anyway, it's always worked fine but on this trip, it only lights when electricity is available. Unplugged...
RustyJC wrote:magic43 wrote:
If your voltage is OK then the odds are that you have a "sail switch" problem.
Going back to the OP's post #1, the furnace works fine when the RV is connected to shore power or the generator. It only fails to light on battery power. Since the fan motor never sees 120VAC, and if the 12VDC voltage supply to the furnace doesn't change irrespective of the power source (i.e., shore power, generator or battery), then the fan motor speed shouldn't change, either. I'm struggling to see how the sail switch plays a part in this problem IF the voltage to the fan motor and, thus, the fan motor speed doesn't change.
Rusty
