okiejoe's avatar
okiejoe
Furnace problem
Ok furnace would start then in seconds go out blower still running the it would reignite the after a few seconds burner goes out again then finally it stays lit. I had the sail switch replaced didn’t help then replaced circuit board and now doesn’t cut out at startup but now runs for about 5 minutes the flame goes out and blower still blows as it should but while blower is still going it reignites and runs again for about 5 minutes then goes out again. Could it be a bad Thermostat??????
