clev's avatar
clev
Furnace problem
I may need to replace the furnace; I really don't know why because it's 'only' 21 years old. Anyway, it's always worked fine but on this trip, it only lights when electricity is available. Unplugged or no generator, the fan kicks on, but there is no ignition. On top of the Medicine Bows, it was snowing, sleeting, and hailing with temperatures in the 40's. It was cold. I have 2 fully charged 6 volt batteries, 220 amps, so that's not the problem. I'm familiar with the basic operation of the furnace, but don't even know where to start trouble shooting. Any suggestions or links would be appreciated. OBTW, the generators worked great but had to be off at 10:00 PM.
  • Check the voltage and for loose connections at the furnace. If the voltage is low, you probably have a battery issue or a converter/charging circuit problem not charging the batteries.
    Ken
  • Sounds more like a battery problem. 12VDC voltage is too low for the furnace to light when the converter (powered by 120VAC from shore power or generator) isn't feeding the battery.
    Rusty
  • Furnace is strictly DC (unless you have an AC style)
    IF it fires up and heats while connected to an AC power source but doesn't w/o AC power than the DC voltage from batteries is low or at issue.
    Check DC voltage at furnace while on AC and w/o AC.
    Dirty/loose/corroded connections/contacts cause resistance. Doesn't take much resistance to stop DC power. The lower the DC voltage the easier for any resistance to impede.
    Good cleaning of contacts at furnace may solve your DC issue
