ford truck guy wrote:
Googled and found it is a common issue with back up camera’s
Did you use a cover during the off season? I had the same issue and found that if the cover moves in the wind it will scratch the lens. I Replaced the camera and then removed it when the rig is covered from Nov to Mar with no more issues. Then I got to thinking if the cover can do this to a glass lens, what about other surfaces? Took a good look at the roof membrane edge streetside where it's not protected by the awning tube and got my answer, almost worn through. No more covers.
