justaboutretire
May 12, 2018Explorer
There is a 30 amp fuse listed for your truck. Should be position 101 and it is a large fuse not one of the Mini fuses. Look under the hood most likely on the drivers side for the power distribution fuse box. It is rather long. A bad ground could possibly cause the brakes not to work. Do the running lights work on the trailer? Check the brake wiring at or on the axles. Possible the wire insulation may have worn away and bare wire to metal grounding.
About Fifth Wheel Group
19,035 PostsLatest Activity: Mar 21, 2026
