2500_Grunt
Oct 20, 2013Explorer
RVpullinGuy wrote:
After reading this entire thread, and based on the size of your family and their ages, I would recommend:
1. I would not get anything smaller/shorter than a 12' garage. You can fit four full-size ATVs in a 12' garage, but not in a 10'. If you have a RZR, that could change things.
2. The desire to upgrade from you little PUMA trailer, will happen again if you end up going with something too small. So, I would consider something bigger than the two trailers you've primarily been talking about. You already decided to get a tow vehicle big enough. I've heard so many times how people wished they had gone bigger and end up spending a lot more upgrading later.
3. I would strongly encourage you to consider the Voltage no matter size you decide to go with. They have a lot of floor plans (which is really the most important thing). They make equally good trailers to the others and better than most.
4. No matter which one you decide to buy, make sure you use the PDI checklists found on this site. PDI = Pre Deliver Inspection. Using a good one and taking your time, can identify problems right off the bat and get them fixed before you leave the lot. Give yourself plenty of time to do it. Some highly suggest you "camp" overnight in the parking lot of the RV dealer to verify all systems before you drive away.
A thought to keep in mind: All RVs will have problems. None of them are made very well. It's just a fact of life. So, pick a Voltage, Fuzion, or Cyclone (when you're ready) with a floor plan you like and don't look back.
That's a great post!
About Fifth Wheel Group
19,042 PostsLatest Activity: Jun 03, 2022
