I just dropped my 315 off to the dealer today for a minor list of warranty issues. The only one on the list that I couldn't easily fix myself without spending a significant amount of money was a slam latch that the lock quit working on. All the other issues were fairly simple fixes, but I after dropping that kind of money on a trailer, I figured it should be their problem not mine.
Overall the quality of the Fuzion line is pretty good in my opinion. Most of my issues are a result of how fast these things are rushed out the door when they are built. The industry as a whole needs to focus more on quality control because I hear the same complaints over and over across all the brands. You would think that it would cost less money to perform better quality control inspection verses paying dealers to fix minor problems.
One issue that you should look out for during your PDI is the slide out drawer under the couch. The end of the sofa that the track mounts to on the right side is on a skew for some reason. They just mount the track flat to the wall and when the drawer is open it causes the drawer to come off track. This is not noticeable until you have the drawer full and it becomes very difficult to move because the weight won't let it slide on the floor as easily as it does when empty. My dealer is fairly new to the Fuzion line but they acted like they had never seen this problem before. My son and I checked out a new 310 that they had on their lot and sure enough it was built exactly the same and the drawer was off track already. I don't know if the 310 was built close to the same date as mine, but I doubt it because this dealer just got it in 4 or 5 months after mine was built. We looked at a 399 also but I forgot to look at the drawer to see if it was the same. Overall, it is an easy fix, but you shouldn't have to mess with it yourself!
