gbopp
Oct 12, 2016Explorer
BarneyS wrote:
I would use some 4" Eternabond tape. It will not come off unless you use considerable effort to take it off. I would probably put a bit of caulking down first to bed the metal plate in and then use the tape around the edges to make sure it does not come off. Any tape left over you can save for roof repairs if needed.
Barney
X2. An adhesive type caulk would probably be best. But, Dicor will do the job. Definitely use Eternabond around the metal, it will not come off.
I would use a piece of aluminum to avoid rust problems.
About Fifth Wheel Group
19,040 PostsLatest Activity: Jul 08, 2013
