Coach-man
Oct 15, 2016Explorer
I purchased a rubber roof repair kit from CW. It has a cleaner, adhesive, and some rubber roofing material. There are only a couple of contact points on the roof, make some patches with the rubber material from the kit, clean the surface, I first used some TSP, a brush and plenty of water. Apply the adhesive and apply the patches. This will make a good base for the antenna to rest on. A better solution is replace the crank up/down antenna with a fixed mount antenna. Never have to worry about cranking it down when you leave, and does not mess with your roof!
About Fifth Wheel Group
19,040 PostsLatest Activity: Jul 08, 2013
