lakeside013104's avatar
Sep 16, 2014
FW tank leaking maybe?
Sorry this is long, but I feel I need to explain in detail.
Packed for trip, hooked up, and filled FW tank for the first time for a 5 night dry camping trip. Heartland says FW capacity for Bighorn 3685RL is 72 gallons (12 in H2O heater and 60 in FW tank). H2O tank was full from a summer of being hooked up to city water.
I tested my S&B home water pump for flow rate and am pumping 6 gallons per minute out of the end of my white water hose. I pumped water for 10 minutes and checked the over flow and the tank gauge. Over flow dry, tank gauge reads 2/3 full. Pumped 2 more minutes, over flow dry, tank gauge still reads 2/3 full.
I turned the lever in the central control center from FILL TANK position to NORMAL position so that I could test water pump inside 5er. Everything worked perfect.
I forgot to turn lever back to FILL TANK position. I opened nozzle on water hose to continue filling FW tank for another minute and thought I could hear water flowing, but not really sure.
I realized the lever was in the wrong position so turned it to FILL TANK position and pumped water for 1 more minute. Over flow dry, tank gauge reads full.
I unhooked hose and started to drive up our driveway. DW says water is running out the back of the 5er????????????
I backed down to the level part of the driveway and watched clean clear water run out of a small hole just over the passenger side rear stabilizer jack for 5 minutes. The FW tank is located above and between the rear stabilizer jacks. Water stopped flowing and gauge reads 2/3 full.
We went camping (for 5 days). When we were setting up, the 5er was tipped toward the overflow side. Water ran out of the overflow until I got the 5er leveled up. We returned home with 1/3 tank of water. Everything was normal with absolutely NO more water leaking anywhere from the 5er.
It appears to me that the over flow line was plugged when I was filling the FW tank. Is that possible on a new unit?
When I had the control center lever in the NORMAL position, is there any way for water to enter the FW tank or any other place near or around the FW tank (between the frame rails)?
Where might this water be coming from?
I realize I need to open up the colorplast membrane and take a look at the FW tank and it’s connections, but I just wanted some input from experience folks.
Thanks.
Lakeside
  • A little confused. When water did come out, was it from the overflow only, or somewhere else too? When I fill ours, I just fill it until water comes out the overflow tube - twice. After the first fill and overflow, I will turn down the water and fill slower until it overflows a second time. And when we drive and the water sloshes around, more water will come out the overflow tube.
