retired-tech's avatar
retired-tech
garage door on SRX320
has anyone found that the garage door is difficult to close. I am having back problems and find that the side door is causing me some difficulty closing. any suggestions would be appreciated.
  • Try removing the extra hinged extension. I don't need mine as I only load motorcycles, and it works fine without it.
  • I had one it wasn't too bad but I think it had room for more springs,also you can remove the little legs at the hinge to make it a little lighter. This fuzion has a patio door and it is really heavy.
  • Contact a local garage door company and see if they can upgrade the springs for you.
