Anybody tow their 5th wheel with a gas pickup if so does it have enough power? I’ve been shopping for a truck to pull a 5th wheel (empty weight is 11,450) and the dealer recommended a diesel. I would...
Any of the later model big 3 gassers will tow that FW with 4.10/4.30 gears. They are rated for a 15K loaded FW weight. Yes, any of the big 3 diesels will do it better. If you stay in your flat country, the gasser will work fine. It will take patience and high RPM in the steep hills/mountains, if you head there, but you will get to the top.
