- Sjm9911Explorer
Dadoffourgirls wrote:
Sjm9911 wrote:
... I will let you all know how it handles in the snow with factory tires in a few days. I have to go into work during the storm over here and im sure if we get a foot or two of snow it will not get cleared. Not sure if i will add weight to the bed yet. I might just see how it handles by itself. It seems heavy enough to get traction without adding weight. But im still undecided as getting stuck is not on my to do list.
I would add a couple hundred pounds. I think that makes the difference for snow traction. I ran between 200 lbs and 400 lbs last winter based on when I needed to feed the Goats or put salt in the water softner.
Unfortunately, i will not get to drive it in the snow. At least not yet. Got called in early so was at work before the snow started and will leave after its done. I really wanted to test it out. - DadoffourgirlsExplorer
I would add a couple hundred pounds. I think that makes the difference for snow traction. I ran between 200 lbs and 400 lbs last winter based on when I needed to feed the Goats or put salt in the water softner. - Sjm9911Explorer
Grit dog wrote:
^ But the cab is the same size as a new GM 1500, so?
And the hard to find diesel one time reason is classic!
I was comparing the size to the old one i had. Much more room in this one. Its also about the windshild, i didn't look at the 1500s this year though. On my 2012 sieara 1500, my eye veiw was at the top of the windsheild and my head was a quarter inch off the roof. The 2002 sierra i had had a much larger windshield veiw when seated. Tbh , i probably could have gotten a sun roof on the 2020 and still have enough room to fit.
Yea, something always sticks in my mind. Lol. Plus i dont need it. Don't plan on going much bigger for a TT. I will let you all know how it handles in the snow with factory tires in a few days. I have to go into work during the storm over here and im sure if we get a foot or two of snow it will not get cleared. Not sure if i will add weight to the bed yet. I might just see how it handles by itself. It seems heavy enough to get traction without adding weight. But im still undecided as getting stuck is not on my to do list. - gmckenzieExplorer
Grit dog wrote:
With most everyone at 8-10 gears. Ridiculously good power output across most all gas and diesel trucks, what is the next “big thing?” I’m running out of ideas to improve these trucks that don’t involve modifying the laws of physics!
IMHO The next big thing will be working electric vehicles. Without range anxiety and with fast charging. But this will be far enough away that the current trucks are still good to buy. - kellemExplorerWith 10spd transmissions and more torque offered lower in the rpm range with these big displacement NA engines, fuel economy doesn't suffer.....that was the goal.
- Grit_dogTrailblazer^Its not necessarily about dropping rpms, it’s about the right rpms at the right time.
10 speeds behind high revving gassers? I would agree, not necessary and 6 gears does 90% + of what 10 will do.
Comparing 5 vs 8 in our last 2 SRTs, honestly also not needed. Better but old was good.
And also not towing.
Imo 8 is the sweet spot and 10 is starting to get redundant on a gasser.
Diesel, about the same. 6 is ok, if they’re the right ratios, 8 is great, 10 has its place in super heavy towing, otherwise getting towards redundancy.
With most everyone at 8-10 gears. Ridiculously good power output across most all gas and diesel trucks, what is the next “big thing?” I’m running out of ideas to improve these trucks that don’t involve modifying the laws of physics! - DadoffourgirlsExplorerMany are discrediting the 6 spd. I am sure that my fuel economy running empty may have been better with a 10 sp. However, here in Michigan, gooseneck towing 16k lbs I never thought I needed another "in between" gear. I am sure somebody has a chart of rpms at speed with 6 gears and with 10 gears. Maybe there would be one speed that I could have dropped rpms. I did most of my 16k lb towing at 55 mph, and did my TT (9400 lbs) at 65.
I also took my TT to Kansas and back in July, but used a Duramax with the 10sp. That allowed me to tow with comfort.
I know that I am biased toward the GM truck. - kellemExplorerWe live far from the metropolitonians where truck buyers were taught to be very biased.
If dad had a Chevy then by gosh you had better own Chevy's your entire life or it was considered BLASPHEMY.
As I got older, I strayed from this mentality and took my licks.
So as an unbiased truck owner, I've come to realize that whoever is offering the best package when I'm in need of a new truck then that's the truck that I end up purchasing.
Two very close friends own 2020 6.6 Silverado's, very sharp looking trucks and both very satisfied.....lots of HP per displacement.
My 2004 Dodge Ram 2500 needed to be retired so the process began to find a new truck to pull our 30ft trailer. Diesel was not a consideration as truck would sit for long periods.
At the end of year long process and research I found Ford to be one step ahead with the 7.3 10spd so bought 2021 F250 and been quite impressed.
I'm sure I would not have been disappointed with the Chevy 6.6 or Ram 6.4 , super nice trucks. - Grit_dogTrailblazer^ But the cab is the same size as a new GM 1500, so?
And the hard to find diesel one time reason is classic! - Sjm9911ExplorerI will add, im tall and it has a lot more room for me in the cab. So everything is bigger. Some might not have these problems, but its nice to atually have head room and to be able to see out the front windsheild. Much better then the gmc 1500 I had. So far for me the 6 speed has not been an issue. But again my TT is light. Towed it on a few long trips this year. All mountains, I had no problems , gas millage was a bit better towing then with the 2012 GMC seirra 5.3 (?) with max tow package. I had plenty of power to pass in the deleware water gap area. With the 1500 I had to slow down to the truck lanes they put in because they cant pull the mountian. The 2500 , not only pulled it but could speed up to pass. And to be honest, thats what i wanted, more control. The 1500 could pull what i had, but the 2500 makes it less of a chore. And i also didnt want a diesel. I still remember going off to a state campgeound up by niagra falls, and my neighbor had to travel like 30 minutes to get to a station that diesel. Hunt and find is not for me. Im sure this is not normal, but it soured me on the diesel thing.
