I tow a 41' Toy Hauler that scales at 16,500 with a 2013 Ford F350 Dually with a 6.2 gas engine and 4.30 gears without any problems. Truck & trailer scale at 24,500. I've towed a 14,500 lb gooseneck horse trailer with this truck and also with a 2006 F250 with the 6.0 diesel, which was not the best diesel engine ever made. Both towed my trailers with no problems. A buddy has a Ram Dually with the Cummins diesel towing a 39' toy hauler that weighs 15,000 lbs. He gets 10 mpg and I get 7 mpg towing. Diesel engines cost approx $9,000 plus more than a gas engine, diesel fuel is averaging about $.75/gallon more than gas, and the diesel has higher maintenance costs. It's hard to justify a diesel with those figures unless you are towing heavy almost everyday. Gas engines & transmissions have come a long way and are getting better every year. Anxious to see what the new Ford 7.3 and GM 6.6 will do. In the end it's a personal preference, but I wouldn't hesitate to buy a gas engine again - just spec it out with the correct rear end and towing package. Do your own research as most salesman are clueless when it comes to spec out a tow vehicle. Dont settle for what's on the dealer lots, order a correctly spec'd vehicle if you have to.
