Anybody tow their 5th wheel with a gas pickup if so does it have enough power? I’ve been shopping for a truck to pull a 5th wheel (empty weight is 11,450) and the dealer recommended a diesel. I would...
I only tow 9300 lbs with my 6.4 4.10 gaser. As far as noise goes, I don't mind it. It's only wound out in the steepest sections of a pass. I lock out 6th or 5th when needed. In 5th it's not the slightest bit noisy. Would I tow 12,000-14,000? Heck no, unless it was mostly on flats or some rolling hills. MPG's would really suck at that point. JMO but anything over 10,000-11,000 is diesel territory if you're in any kind of hills or mtns a lot.
