Bighorns wrote:
paulm235 wrote:
Thanks Bighorns! How did you handle the pressure regulator on the grill? What did you do to get the other end connected to the grill. I just ordered a portable grill so I haven't seen it yet. I do know it has the regultor on it as I think most do. I'm curious as to how you removed the regulator...cut it off, can you unscrew it, etc.? I'm guessing it's porbably a per grill issue. How did you handle yours?
I was able to just unscrew my regulator and then screw the new quick connect on, and I also had a longer hose made that I could screw the quick adapters onto and be able to set my grill in different places if needed. I have a weber Q grill, but it is probably different from grill to grill on what you have to do. If I have time to go to my storage I will take som pictures and post them for you.
Thanks again Bighorns. Don't go out of your way. The grill I ordered should come Tuesday and what you just told me will give me a better idea of what to look for. I'll update after it comes.
