Lantley
Oct 29, 2016Nomad
RAS43 wrote:jnharley wrote:
We use electric only unless we are dry camping and then obviously, we use propane. We have no issues with recovery with back to back showers just on electric. I do not think we ever have run out of hot water and I only turn on the hot water when I shower.
X2 Also never had an issue with running out of hot water. And only once did the breaker trip when running the heater, A/C, and converter and that occurred when my wife turned on the microwave. We have 30 amp service.
When using the HWH on electric on a 30 amp site the issue is not running out of hot water but more with running out of electric! You run the risk of tripping the breaker if someone makes the wrong electrical usage move.
Really no big deal but switching HWH to LP will reduce overall electric comsumption without compromising water usage.
You will still need to use energy management technique but putting HWH on gas will give you a bit more freedom to use microwave, hair dryer or whatever without issue
About Fifth Wheel Group
