ijon1's avatar
ijon1
Gas pump
What is a good replacement pump for my fuel pump on my fury 2910 tow hauler. It is a piece of junk and sticks.
    What brand model of pump?
    If Great Plains RV model - get a kit for an EZ8 model -same pump just different model # to force purchase of parts thru RV dealer at increased cost. I learned the hard way.....
  • Believe it or not the gears will swell in the presence of gas. My last toy hauler, I had to open the pump head up and sand the gears twice. They are easy to come out, place the sand paper on a table and rub the gears around. Does not take much.
    Mark
  • Get a replacement set of gears and / or when the pump is stuck just slightly loosen the 4 bolts on the end/top plate. My pump works when it's cool, but not if it's been out in the sun.
    You can also slightly sand the gears to add a bit more clearance.
