87 royal coachman 454 classA occasional whiff of gas strong in coach in few minutes it disappears parked in driveway doing cleanup prep for a run nothing turned on except shore power gas tank was ...
When I had occasional fuel smell in my auto the mechanic plugged in a device which I assumed pumped smoke into the fuel system which helped him identify the problem -- wasn't very expensive. The device he used was mobile so it wouldn't even require a repair bay ... but make sure you tell the mechanic how big your rig is.
