- DiskDoctrExplorer
valhalla360 wrote:
Sorry if calling a use case that is multiple standard deviations from normal "silly" hurt your feelings.
Nope. Your choice of words are your responsibility. Rudeness and disrespectful comments belong to the author and a reader's "feelings" do not change that one way or the other.
Blaming others for your bad manners only results in repeat offenses.
And your claim of "multiple standard deviations from normal" is only your opinion and already shown to be wildly incorrect.
But you can continue to prop up your opinion using some fantasy million mile gas engine and repeated claims that at 200k all vehicles must be delivered to the scrap yard because they are worthless.
Of course you are also assuming no one would ever use a diesel for any other trips or purposes, just a few trips a year- except for Carnies in your words.
I guess you are also offended when anyone uses their trucks for transportation instead of towing a camper. How dare they put miles on their trucks :R
Taking a trip with 8 people in a large diesel SUV where everyone has lots of room and splits the fuel costs and spends time together as friends and family must really get your gut in knots. A thousand miles in a weekend? Oh the horror!
Guess what else. Some people even use their vehicles for work!
And you know what else. There are even folks who ENJOY driving their trucks and might even...gasp...drive them daily ;)
Say it ain't so, Joe. ;)
If it doesn't fit in your "opinion box" it must be due to someone's feelings or their silly ideas. - lazydaysExplorer
rhagfo wrote:
4x4ord wrote:
4x4ord wrote:
lazydays wrote:
Since 2003 I've pulled different campers with a Ford 5.3l, Chevy 6.0l, Dodge V10, and Chevy 6.6l diesel. No way would I go back to gas. I've owned the diesel going on 7 years and have only put 42k miles on it so I very rarely use the truck. Mainly weekend driving and pulling the camper in the Summer. Cost of ownership means nothing to me or I wouldn't own a camper, boat, multiple cars, ect. Took my Dad who almost 70 when he finally realized that diesel was the way to go and he's on his second now.
You might find that there are some 2018 gassers that will tow nicer than your 05 Duramax does.
I want to put some numbers to my claim that a new gasser would out tow an old Duramax. The 2005 Duramax was capable of putting a maximum of 3500 lb ft of torque to the rear axle in 2nd gear. The truck at that point would be traveling 22 mph. The 2018 6.2 Ford equipped with a 4.10 rear axle can put nearly 4400 lb ft of torque to the rear axle in second gear. At that point the gasser would be traveling 41 mph.
While the trucks are running 60 mph on level ground where little power is needed both engines would be turning quite similar rpm. (The 2018 gasser in 6th vs the 2005 Duramax in high gear or 5th). The Duramax would be quite comfortable at 60 mph in 5th gear were as the 6.2 gasser might be requiring a downshift or two as soon as a bit of grade increase comes along.
LOL! Love comparing a 12 year old diesel to a new gas engine!!
Yes, pulling power of gas has come a long ways, but so has diesel even with the emissions gear!
5th wheels keep getting bigger, longer, and heaver, best choice is still a diesel for any 5er over 12,000#.
If my truck was stock I would agree. Point is I have no use for a gas motor and as long as I'm pulling a 12,800lb camper down the road it will be diesel for me. - rhagfoExplorer III
5th wheels keep getting bigger, longer, and heaver, best choice is still a diesel for any 5er over 12,000#. - 4x4ordExplorer III
JIMNLIN wrote:
Taylor90 wrote:
I have some issues picking a suitable towing vehicle to haul a travel trailer. Gas vs diesel for towing a fifth wheel? Which one is better? Any suggestion?
Probable already mentioned but we have pages and pages of diesel vs gas over in the tow vehicle section. Usually mods/adm will move tow vehicle questions over there.....guess things are a bit slow in the 5th wheel forum.
Its really simple. Non of the gasser's can tow heavy trailers without lots of rpm and noise...and a diesel isn't necessary for a lighter weight trailer.
And if your trailer is between heavy and light weight then simply choose a gazz or a diezzul powered truck....in white of course ;)
It really is that simple. However 10 years ago a diesel was a huge improvement over a gasser for a 12000 lb Rv. Now a 12000 lb rv can be easily towed with a gasser. Most RVs are under 12000 lbs and most of us buying new diesels would have a pretty tough time justifying the need of one for our little trailers. - JIMNLINExplorer III
And if your trailer is between heavy and light weight then simply choose a gazz or a diezzul powered truck....in white of course ;) - 4x4ordExplorer III
While the trucks are running 60 mph on level ground where little power is needed both engines would be turning quite similar rpm. (The 2018 gasser in 6th vs the 2005 Duramax in high gear or 5th). The Duramax would be quite comfortable at 60 mph in 5th gear were as the 6.2 gasser might be requiring a downshift or two as soon as a bit of grade increase comes along. - dougk53Explorer
goducks10 wrote:
I don't look at it as a cost per mile thing at all. I got the diesel option cause I wanted it. Same as those who get the Laramie/Lariat option. How about the bigger screen on your radio? The fancier rims? etc. It'a all part of buying a car or truck. Just option it out like you want, drive it until your bored with it and get another.
This speaks volumes. It is not what is better towing a fifth wheel, it is what size fifth wheel you are going to tow and your personal preferences and comfort level.
We recently traded into a Ram 2500 6.4 Hemi to tow a 7700# TT. A diesel for us would almost never make sense as at our age trading out of a 2 year old TT that meets almost all our needs would make little sense just as $9000 for a diesel plus $.75 more per gallon for fuel in our area outweighs all other considerations.
We also lease our trucks now as we get new about every 3 years or less. Have owned vehicles with up to 400,000 miles on gas engines. Some will say leasing makes no sense but it does for our lifestyle, at least our trucks.
For us the cost difference for a diesel is better spent traveling. If you tow heavy diesel is the only option but it comes down to first your needs and second your wants and only you can determine those things.
Good luck.
Doug - valhalla360Navigator
deltabravo wrote:
Ask the guys that transport RVs from factories to dealers... rarely will one say "gas is better for heavy towing".
I did summer time transport in 2014 and 2015. DIESEL all the way, even though I wasn't towing heavy. Units I hauled were 21-25 feet most of the time. I had a very easy route too, with minimal change in elevation, but I still prefered diesel for that route.
Again, this is a commercial application where other things are driving the choice:
- Most will at least occasionally get a heavy trailer where they need that extra power to stay within the ratings. (you also dont' need a 1ton dually to pull a 23' trailer but most will have that)
- Most are doing a ton of miles towing where the fuel efficiency really makes a difference to the bottom line. They can amortize the upfront cost of the diesel with fuel savings.
- If you are putting 50k miles per year on a truck, in 10yrs they would be at 500k miles and yeah, they probably would be on their second gas engine and considering if they need a third.
By contrast your average RV buyer with a 23ft travel trailer:
- Doesn't need the diesel power due to weight limits.
- Usually only does a couple thousand miles per year and the fuel savings might buy a dinner out once a year. It will never cover the up front cost of a diesel. (I'm talking the big diesels not the new 1/2ton small diesels)
- Usually only does around 12,500 total per year giving 250k gas engine a 20yr lifespan, so either engine is good for the life of the truck. - valhalla360Navigator
DiskDoctr wrote:
valhalla360 wrote:
But given the available engines, the idea that a typical non-commercial diesel will outlast a gas engine by 2-3 times is just silly...
Of course, if you really are putting 500k miles on a pickup (maybe 50k/yr on the carnie circuit),
Listen, you're entitled to your opinion, but others are capable of making their points without being disrespectful or rude. Perhaps you could show similar courtesy to your fellow posters.
Google: Ad Ignominiam Diversion
It's an invalid argument to mock others' position and it is considered quite rude and often inflammatory.
Make your case respectfully or move along.
Sorry if calling a use case that is multiple standard deviations from normal "silly" hurt your feelings. Inflammatory would be calling you a name. This was highlighting an argument that is misleading.
Generally, cars & trucks are assumed to have a lifespan of around 20yrs and the average mileage per year is around 12,500...which works out to around 250k miles...which pretty much matches up with the life of a gas engine.
So if a gas engine lasts 250k miles...it already lasts the life of the truck. It's unlikely to have an engine replaced. Lasting long enough to get to the third engine is exceedingly rare.
I've seen a story a few times about a guy who has an old Volvo that at something like 1.5million miles but to claim it as justification to buy a new Volvo that is a completely different design is silly.
But let's say you do get to the point of having to replace the engine: A diesel runs $8-10k more up front. A replacement gas engine can be dropped in for around $5k-6k if you really do reach that point, so you are still ahead of the game and a 40yr old diesel is going to have negligible resale value in most cases (as will a 40yr old gas truck). - 4x4ordExplorer III
About Fifth Wheel Group
19,031 PostsLatest Activity: Dec 16, 2025
