AJBert
Aug 11, 2015Explorer
Check the easy stuff first. Remember, you only need three things to get combustion.
Air - already been mentioned
Fuel - check
Spark - first check to make sure the boot didn't come off the plug. If not, check for spark
I had the magneto go out on my generator in less than a year. Hopefully that's not your problem.
If you have spark, spray some starting fluid through the carb. If it starts time to rebuild the carb. If it doesn't start and you have spark...ummm...probably time to bring it into the shop, unless you have knowledge of tearing down small engines.
Fuel - check
About Fifth Wheel Group
19,032 PostsLatest Activity: Jan 04, 2026
