nayther
Nov 10, 2015Explorer
taken wrote:
Your carb float may be stuck causing the engine to flood.
Wrong, it would run or at least try to with starter fluid. The old story, if you have gas, spark and compression it MUST run. Try the starting fluid again with the air cleaner removed, just a short squirt and open the butterfly manually, see if it fire. If it fires I'd suspect carburetor issues. If it doesn't then I'm at a loss without being there.
About Fifth Wheel Group
19,032 PostsLatest Activity: Jan 29, 2024
