pianotuna wrote:
This is slightly true but ONLY if the two generator types have similar outputs. i.e. compare a 5k inverter to a 5k traditional--and the inverter may not win on fuel economy.
laknox wrote:
If you want long run-time, then get an inverter-style generator as it will only run at the speed needed to supply the load demand. You'll burn a =lot= less fuel than with a straight genny, like the Onans.
Lyle
Hmmm... The Honda 7000i burns 0.784 g/h at rated load while the 6500 burns 0.887 g/h at its rated load; a 13% difference. The 6500 runs wide open all the time; the 7000 will idle down based on load. Pretty straight-forward to me...
Lyle
