avvidclif1 wrote:
Why don't you just toodle down to Texas in August and you'll figure out why battery banks and solar just don't cut it.
Single Honda 2000 combined with a Magnum or Victron inverter that combines power will easily run an air conditioner 24/7 in all conditions. Will also run the microwave or hair drier when needed at the same time as these units synchronize and combine power with the generator. The start surge or additional load is carried by the inverter until done then any excess power is charging the battery. Solar would be charging all day as needed. Need an extended run fuel tank for a TX Summer.
Although if such convenience is desired I am not sure why a built-in generator was not optioned.
